Camera's for extra printers
Hi everyone,
I'm rather new to Repetier server, and I'm running Repetier-Server Pro 0.86.2 on a raspberry pi 3 with 7" touchscreen, to control 3 3D printers.
This means that already 3 USB ports are taken for the 3 printers, leaving the pi camera port, 1 more USB port and IP camera's as possible solution, since I would like a camera per printer.
The pi camera works fine, but I can't get the USB camera to work, although it shows up in the list to select and I have a -video0 in the /dev list when I connect via the SSH client, for the USB camera.
I was planning to add a few IP camera's. For this I had a few raspberry pi zero's with wifi, running motionEyeOS.
They work fine when you type the IP address in a browser and log-in, but I have no idea how the add them as extra camera's to Repetier -Server or if that is at all possible.
Any thoughts on how to connect them?
Thanks in advance for your help
Thanks for the advice
