Updated to latest 0.86.2 on RPi3 (14.Aug.17) - BAD GATEWAY / REFUSE TO CONNECT?
edited August 2017 in Repetier-Server
Hi all,
Just autoupdated to RepServer 0.86.2 and something weird has happened. I waited for a while for it to update and then when I rebooted, it just gave me 502 Bad Gateway from the web interface. I plugged a monitor up to it to see if it would boot into the interface, but instead, it just says "127.0.0.1 Refused to Connect"
Any ideas on what could be going on?
  • 0.85.2 has some serious bugs, so please install 0.86.2 and hope that bug has not deleted printer configuration.  If 127.0.0.1 is refuses to connect it could mean the server crashed for säome reason so no interface to connect to. If 0.86.2 does not work check /var/lib/Repetier-Server/logs/server.log for hints.
  • Oh, that is the version I have-- my mistake. It's whatever was most recent when updating from the web interface. Annoyingly, I forgot to set my proper time so my logs are a little off. Here's what has come up:
    2016-12-08 09:31:36: Start logging...
    2016-12-08 09:31:36: Imported external command Shutdown Server
    2016-12-08 09:31:36: Imported external command Reboot Server
    2016-12-08 09:31:36: Webdirectory: /usr/local/Repetier-Server/www/
    2016-12-08 09:31:36: Storage directory: /var/lib/Repetier-Server/
    2016-12-08 09:31:36: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
    2016-12-08 09:31:36: Directory for temporary files: /tmp/
    2016-12-08 09:31:36: Reading firmware data ...
    2016-12-08 09:31:36: Starting Network ...
    2016-12-08 09:31:36: Active features:0
    2016-12-08 09:31:36: Reading printer configurations ...
    2016-12-08 09:31:36: Starting printer threads ...
    2016-12-08 09:31:36: Starting work dispatcher subsystem ...
    2016-12-08 09:31:36: DNS error: Temporary DNS error while resolving: download.repetier-server.com
    2016-12-08 09:31:37: WorkDispatcher table created successfully
    2016-12-08 09:31:37: Starting user database ...
    2016-12-08 09:31:37: DNS error: Temporary DNS error while resolving: licence.internetloesungen.com
    2016-12-08 09:31:38: Initalizing LUA ...
    2016-12-08 09:31:38: Starting wifi watcher ...
    2016-12-08 09:31:38: Register LUA cloud services
    2016-12-08 09:31:38: add Repetier-Renderer
    2016-12-08 09:31:38: LUA initalization finished.
    2016-12-08 09:31:38: Starting web server ...
    2016-12-08 09:31:38: Work dispatcher thread started.
    2016-12-08 09:31:38: Webserver started.
    2016-12-08 09:31:40: Activating access point
    2016-12-08 09:31:47: Host not found: licence.internetloesungen.com
    2016-12-08 09:31:57: Host not found: licence.internetloesungen.com
    2016-12-08 09:32:07: Host not found: licence.internetloesungen.com
    2016-12-08 09:32:17: Host not found: licence.internetloesungen.com
    2016-12-08 09:32:27: Host not found: licence.internetloesungen.com
    2016-12-08 09:32:37: Host not found: licence.internetloesungen.com
    2016-12-08 09:32:47: Host not found: licence.internetloesungen.com
    2016-12-08 09:32:57: Host not found: licence.internetloesungen.com
    2016-12-08 09:33:07: Host not found: licence.internetloesungen.com
    2016-12-08 09:33:17: Host not found: licence.internetloesungen.com
    2016-12-08 09:33:27: Host not found: licence.internetloesungen.com
    2016-12-08 09:33:37: Host not found: licence.internetloesungen.com
    2016-12-08 09:33:47: Host not found: licence.internetloesungen.com
    2016-12-08 09:33:57: Host not found: licence.internetloesungen.com
    2016-12-08 09:34:07: Host not found: licence.internetloesungen.com
    2016-12-08 09:34:17: Host not found: licence.internetloesungen.com
    2016-12-08 09:34:27: Host not found: licence.internetloesungen.com
    2016-12-08 09:34:37: Host not found: licence.internetloesungen.com
    2016-12-08 09:34:47: Host not found: licence.internetloesungen.com
    2016-12-08 09:34:57: Host not found: licence.internetloesungen.com
    2016-12-08 09:35:07: Host not found: licence.internetloesungen.com
    2016-12-08 09:35:17: Host not found: licence.internetloesungen.com
    2016-12-08 09:35:27: Host not found: licence.internetloesungen.com
    2016-12-08 09:35:37: Host not found: licence.internetloesungen.com
    2016-12-08 09:35:47: Host not found: licence.internetloesungen.com
    2016-12-08 09:35:57: Host not found: licence.internetloesungen.com
    2016-12-08 09:36:07: Host not found: licence.internetloesungen.com
    2016-12-08 09:36:17: Host not found: licence.internetloesungen.com
    2016-12-08 09:36:27: Host not found: licence.internetloesungen.com
    2016-12-08 09:36:37: Host not found: licence.internetloesungen.com
    2016-12-08 09:36:47: Host not found: licence.internetloesungen.com
    2016-12-08 09:36:57: Host not found: licence.internetloesungen.com
    2016-12-08 09:37:07: Host not found: licence.internetloesungen.com
    2016-12-08 09:37:17: Host not found: licence.internetloesungen.com
    2016-12-08 09:37:27: Host not found: licence.internetloesungen.com
  • Looks at least if server starts and there are no printers configured and wifi is also not setup as it boots into accesspoint mode. Did you setit up yourself ot is this our pi image for 0.86.2?
  • It is your image.
    I fixed it by simply redeploying the update. I guess something got messed up somewhere!
