Repetier-Servoer 0.85.2 on RPi3 Cannot Connect To Printer
I have installed the latest Repetier-Server (0.85.2) on an RPi3 and the installation appears to be okay. The server is running and I can connect to it from other boxes. My problem is that I can't connect to the printer. I have tried all the USB ports on the RPi, and I have tried a bunch of the /dev/tty ports in the printer settings, including the 'serial' ones.
Yesterday, after I completed the installation I was able to 'connect' to the printer via /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0, but there was no response from any G-code commands. By 'connect' I mean that the printer icon turned green and the 'Get Values From Firmware' button appeared to work - it didn't give any errors and was re-enabled after a few seconds. However, the RPi crashed sometime overnight and since then I haven't been able to connect at all (no change in icon, etc.)
Any help or pointers on what to do or look at would be greatly appreciated.
M115
to see which firmware it really is and not the baud rate.
10:58:07.932 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
10:58:07.937 : echo:Active Extruder: 0
Using the RPi as the printer server will enable me to move the printer away from my desk to a better ventilated location.
Thanks for your help.
