connecting repetier-host to Makerbot's replicator 2...
Hi everyone,
I've got my replicator 2 bot and i wanted to go a deeper into different slicing techniques.
so far repetier seems to provide the best preview per slice, and best feedback from the all different slicers under the same roof.
however i haven't been able to find any info on how to get the 2 working together.
I Managed to connect them but when i hit print it just stays on printing mode 0% and nothing is happening.
Is it at all possible to send sliced models to the makerbot via reptier?
I gathered the makerbot firmware might not support this .
can upload a different firmware on the makerbot?
any help would be highly appreciated.
thanks
They used binary optimized protocol very similare to gcode.
There open-source Firmware:
* http://www.sailfishfirmware.com/
* https://github.com/jetty840/
There descriptions for command protocol (binary)
* https://github.com/jetty840/Sailfish-MightyBoardFirmware/blob/master/firmware/src/MightyBoard/shared/ProtocolDocumentation.hh
And also There open-source gcode-x3g converter (with usb support commands)
* https://github.com/whpthomas/GPX
So, can you do support for this protocol? it is very huge count of China/Japan companies who clone Duplicator 2X and same count peoples who want support from Repetier-Host
https://groups.google.com/forum/?fromgroups=#!topic/makerbot/MISZe84b1pU[1-25-false]
And there descriptions about sailfish and differences
http://www.makerbot.com/sailfish/
http://rhplugins.repetier.com/1_00_classes/html/interface_repetier_host_extender_1_1interfaces_1_1_i_printer_connection.html#a86adba478a19134a63b8ff95aaa5e46f
I think try to do this thing...
I installed Sailfish firmware when ReplicatorG stopped existing.
Then Sailfish stopped existing as far as Linux goes.
The printer worked great. until 2 years ago when Linux support stopped.
Now it sits in the corner with a thick layer of dust.
Cura doesn't support it.
You don't support it.
Makerbot doesn't support Linux
Unmet dependancies abound.
Nobody supports it.
Please reconsider and see if you can get it to work under Repetier.
If you live in the U.K. I'll drive down and hand you my printer for as long as is needed.
I am really begging you to find out how to make this printer work in Repetier.
