Hello, I'm not a native english so I gonna try to do the best I can.
I recently bought a 3D printer but when I slice with slic3r or skeinforge, repetier host crash, when I try to load a Gcode file, repetier host crash too, do you have an idea for fix it ?
Thanks.
Do you have opengl 1.5 or higher running (shown in log) and enough free memory?
I didn't find the OpenGL's version but here is the crash report.
But where is the work directory ?
When I placed with visualization quality I found that Adaptive Volume causes a crash while the other 4 settings seem to work. Since filament visualization is very heavy operation you should select medium.
What is the problem you have? Not selectable because no object is selected (boxed in blue lines)?
