Fan Keeps turning on and cooling below set nozzle temp.
Hello. I am new to printing and suck at programming, but I am having an issue with my extruder fan cooling my nozzle to a lower temp than set. Then, when I turn of the fan, it will turn back on automatically. Please help and if it is super code "go into the firmware and change this..." oriented, as much detail as possible is greatly appreciated. Thank you do much!
The only fan you can control is the filament cooling fan and that gets controlled by M106 and M107 but this is not the fan you ente rin extruder configuration for extruder cooling.
