I recently upgraded to Repetier Host v2 and can no longer communicate with my printer
I recently upgraded from Repetier Host 1.6.2 to 2.0.1 on a Ubuntu
14.04LTS PC Desktop connected to a Makers Tool Works MendelMax 3 (via
USB). The MM3 is running Marlin Firmware that was provided by the
manufacturer.
Everything was running reasonably well before the upgrade. Since the upgrade to RH 2.0.4 I have not been able to communicate to the printer. The "Connect/Disconnect" Icon on RH switches from one to the other but it doesn't seem to be communication with the printer.
I see the following in the RH GUI and logs:nn Commands Waiting
No start signal detected - forcing start
N1 M110*34
N2 M115*36
N3 M105*36
N4 M114*35
N5 m111 s6*98
JOV?f?J?z?%iE$%?JXF?*( run on string of random looking characters...)
Communication timeout - reset send buffer block
A search of faq's and posts all seem point to communications configuration. I've verified that the "Printer Settings" are correct (baud rate etc.) and the MM is connected properly.
Does anyone know what the solution might be?
Michael
I re-ran configureFirst.sh and InstallDependenciesDebian and it works.
My Bad
Michael
