Thermistor error, just flashed DaVinci 1.0a to Repetier
Hey everyone,
I'm new to 3D printing so go slow
Anyway, I just successfully flashed my DaVinci 1.0a to Repetier 0.93 and have host V2.0.1 installed.
When I send a print job to the printer I get the error in the screenshot below. I've searched the forum and haven't found anything that corrected the issue. I was not able to find the settings that others have suggested changing in my software. The machine worked without issue using XYZ's software and firmware yesterday
Suggestions?
Suggestions?
So what it said is I powered the bed for 31 seconds but the temperature did not rise at all. So that can not be correct and for safety it disabled all heaters. Since you see a bed temperature I guess the heater is getting simply no power. Reasons:
1. Power not enabled
2. Wrong pin for heater so it powers something else.
3. Not correctly wired.
I was actually able to get it working by grounding the bed to the chasis..... so not sure what is going on there.
Eric
