Server won't start on windows 10 after working fine.
For whatever reason, Repetier Server service refuse to start. It has been working fine for days before.
here is the error in Windows events log:
Nom de l’application défaillante RepetierServer.exe, version : 0.0.0.0, horodatage : 0x5849222c
Nom du module défaillant : RepetierServer.exe, version : 0.0.0.0, horodatage : 0x5849222c
Code d’exception : 0xc0000005
Décalage d’erreur : 0x00035e20
ID du processus défaillant : 0x9b4
Heure de début de l’application défaillante : 0x01d2db936b816378
Chemin d’accès de l’application défaillante : C:\Program Files\Repetier-Server\bin\RepetierServer.exe
Chemin d’accès du module défaillant: C:\Program Files\Repetier-Server\bin\RepetierServer.exe
ID de rapport : af2fbb3c-bb91-470f-8c40-e7a0dc948e56
Nom complet du package défaillant :
ID de l’application relative au package défaillant :
Sorry it's in French, but error numbers are easy to translate.... :-)
I tried rebooting, re-installing, same. No ideas what to do next!
Thanks for your help,
Bernard
Sorry, forgot to say: as the version is not displayed, I should have said it's with the last one: 0.80.3
Bernard
If it now works, I would really like to know which corruption the problem causes. So you could stop server and add parts of the renamed folder to the new created folder and restart to test. I would start by adding database directory bag, so you have your old license data etc back after the restart.
Next turn configs and then the printer folder parts.
At some point it will not start any more and then you know one of the files added causes the crash.
If you look int the log/server.log file you might maybe reduce the search as server logs it's steps and seeing how far it comes might also narrow the problem. In any case should renaming and restarting folder make it work again.
Thanks for your help, and a great suit of softwares...
Important: Always stop server before adding/changing files manually. Otherwise it might get confused or write old data etc.
On restart all databases not present get replaced by new ones, but of course empty.
Here from server.log what it looks like on a normal startup:Read configuration file
/Users/littwin/Documents/Projekte/Repetier-Server/Repetier-Server/repetier-server.xml
For you of course with different printers. But from the progress there I could see how far it goes and if it happens while loading the database or scanning the printer folders for gcodes present. Especiall in models/jobs folde rof printer a defect .gin file was able to cause troubles. Next release will autofix defect .gin files. You could delete them before starting as they would get rebuild on startup then.
