Instructions for Custom Touchscreen not working
I followed instructions found here: https://www.repetier-server.com/printer-touchscreen-customization/
Tried all kinds of different urls to access my variant, but I keep getting "Requested file not found."
Are the instructions still valid for Server 80.3 (on windows).
Is there a way to allow folder browsing to figure out the right url?
  • That is the old touschscreen that is discontinued, but still included and working. For the new touchscreen frontend see
    https://www.repetier-server.com/customizing-printer-frontend/
    and the chapter in the server manual for normal activation. Windows and Linux use both the same urls,so
     http://localhost:3344/modules/front2/www/app.html/
    should be correct for all versions if it is running on same device (which is required for it to work with users enabled).
  • Thanks. Please add note and link to the old instructions page, that there is a new version which can be customized as described in https://www.repetier-server.com/customizing-printer-frontend/
    Thanks anyway
  • So, I followed the new instructions, but "npm install" fails (using NodeJS 6.7). see attached logfile.Tried to run command with Admin priviledges too, same result though.
    I have almost zero npm knowledge, so please help me
    In turn, I will provide you with step-by-step guide to add to your instructions!
  • This is a bit tricky as there are so many versions and dependencies. I'm quite sure I have modified the download to already contain node_modules directory with all dependencies so it works. So please reunpack und omit the npm install part.
  • OK, would love to try, but the instructions are not clear enough for me to find the files to be edited. Too many www, front, front2 folders in C:\Program Files (x86)\Repetier-Server
    All I would like to do is change the size of the GUI to fit my X220 tablet PC (1368x786)...
  • I agree that this is mor esomethign for webprogrammers than non programming users.
    In your case all you want is a different css so forget javascript and add just your resolution, which is
    Display:
    • 12,5" 1366x768 HD, LED-Backlight
    • 12,5" 1366x768 Premium HD, LED-Backlight, IPS-Panel (FRU 93P5675)
    as I found in internernet. Will see if I can add this for next update as additional breakpoint.
  • I do have (an outdated) programming background, but I cannot figure out, what CSS I need to edit....Could you please indicate the right path. There are many options....
    And just to make sure I am barking up the right tree, I do not need to download the source, but can make the changes in the Repetier-Server installation directory, right? (Properly backed up of course)
    Thanks!
  • Please try this ui.css
    https://dl.dropboxusercontent.com/u/74036902/ui.css
    should be in install/www/front2/www/css
    I have added an additional breakpoint with your resolution.
  • Ok, I give up and wait. The css is compressed and there are simply too many "width" references in that file. Could not figure out which one to change....
  • The one I gave you has your changes already included. YOu should just replace it.
