Temperature Profile Question
I ordered new thermistors for my Delta Printer, using Repetier host.
The seller ad said "Use it with heated bed or extruder, have to select "TEMP SENSOR_0" before using".
Where to I find this code to check it for proper setting?
  • This is part of firmware configuration. You need to recompile your printer firmware if you use different thermistors. Question is for what firmware this is. 0 is EPCOS B57560 thermistor which was widely used at the beginning but is not produced under that name any more.
