How do I complete eradicate Repetier Server from my iMac
How do I complete eradicate Repetier Server from my iMac.
After days of trying to get a Apple iMac driver installed - and finally succeeding.... because of other issues I was advised to try the Server.
I did, it does not control my Anet A8 printer - but worse - when I go back and open Host - even though teh driver is listed in the printer preferences/settings - Host cannot connect to the printer. Noe can the new 2.5 Cura - which DID before I installed the server.
Its not an app that c an be deleted - but I have deleted its file in the Library. I am now back to where I starte 2 weeks ago with a printer that can only function by SD card.
Advice please to get rid of any trace of the Server and can any Apple iMac guru advise on installing a driver that goes through the install procedure - but does not show in the terminal - ls/dev/tty* check.
