Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Server
Raspberry Pi Camera how to get working
dmkmedia
March 2017
in
Repetier-Server
I have the server installed on a raspberry pi and also I have the raspberry pi camera
how can i use the raspbery pi cam in the server software
Repetier
March 2017
If you use our server image it is just select it in printer configuration, webcam tab. It will then show a dropdown to select a webcam you can assign. Otherwise read
https://www.repetier-server.com/setting-webcam-repetier-server-linux/
to see how to do the same manually.
pietroberto12
March 5
i didn t use your image how i can setup manually?
Repetier
March 6
Setup mjpg_streamer to stream th epi cam and enter the static and dynamic url in the server.
describes a possible way.
Sign In
or
Register
to comment.
