Just tried to adjust a EEPROM value (Z max length), but the new value was not stored. After disconnecting and reconnecting the EEPROM tab is kind of messed up. See attached screenshots:
Sure it is. It is even easy if you open a terminal in a separate window and select display commands. Then do it in eeprom editor and you see a M206 in terminal. Then replace the S with X for float values and resend.
