repetier-host and multiple printers
Can Repetier-Host or Server control multiple printers?
I have a Geeetech G2 Delta and a Tevo Tarantula that I would like to connect and run off my main computer. Not looking to run at the same time unless its an easy possibility.
  • The server can handle multiple printers at the same time. That is what it was designed for. Host can handle one printer at a time but can have multiple printers degined. You can also start it multole times but that uses more resources on computer and can cause problems if both slice the same time.
