Meas. Probe Height on latest dev
When I use the "Meas. Probe Height" feature a point gets probed and the log returns:
2:31:10.421: Z-probe:NAN X:100.00 Y:100.00
2:31:10.433: Z-Probe height set to: NAN
After that, Z-Probe Height is no longer listed when viewing the EEPROM setting with Repetier Server. To correct it, I exported my EEPROM, updated Configuration.h and changed the EEPROM set and reflashed. Z-Probe Height reappeared in EEPROM settings. I was able to import my EEPROM settings.
I tried it several times with the same results.
Running a MKS Base 1.2. Repetier Server 0.80.3 and the current version of dev from https://www.repetier.com/firmware/dev
