Gcode log for resuming
Hi, is it possible to add a gcode logfile? Im thinking it would help manual pause & resume when the printer has to be restarted. The idea eould be to find the last printed gcode and manually edit the gcode file to start from that point. This could obviously be even more user friendly by just saving the printing position in repetier server and offer resume when the printer reconnects but that is obviously a lot more work than a log file.
  • Log is already available. In printer context menu enable log.
  • Yes but if the power goes out all is lost. I want it to log to a file.
  • Yes activating "Log communication when printing" stores the last 5 print to file, then it overwrites the oldest file. You will see the files in the same window after print.
