@pause in repetier firmware 0.91 via repetier-server
Is @pause embedded in g-code stored in and printed by repetier-server supposed to work with 0.91 firmware? So far my attempts to print files from the repetier-server file list that have embedded @pause entries seem to result in the pauses being ignored. I would have assumed that the firmware version was irrelevant and that this was handled by repetier-server itself, but something is amiss. Thanks very much.
  • @pause Message
     is interpreted by server and should make a print pause. It only works while printing but then you should be able to do it even in console for testing. Make sur ethe line start directly with @ or ;@ and no space before, all lower case.
  • I'll run some more tests. Thanks.
  • Ah. I was testing using uppercase. Thanks.
