No manual control works with repetier firmware, does work with marlin?
host to marlin firmware can do manual control all steppers and heat etc.. great Everything work.
Decided was time to try the Repetier firmware like the control and LCD Layout a lot better. Used the same config as above used the new config h upload tool, followed the prompts, added the watch dog and stepper delay as suggested for using the corexy settings. Host to Repetier upload firmware to mega2560 and ramps 1.4 compile and upload worked, the display LCD and controls all are displayed. Connected to the host: all looks good.
However when trying to manually select a function like
the motors heaters etc, selecting just makes
the check disappear nothing is physically working. apperently no power as no heat or any other control functions, nothing
is physically working?
Switch back to the marlin firmware everything works?
did not find any marlin or ramps related searches apologies if not in the correct area.
Thanks in advance,
Any ideas?
This seems very weird as it did connect just no control before. may have been the the baud rate may have been set to 115000 instead of 250000 Yeah
