Communication issues with Lulzbot Mini
Ive tried using the downloaded Mini config file and using custom setting in the printer tab and both arent working.  Could someone shed some light on hooking a Mini up to Repetier Server.  I've tired earlier version of the Server with  same results.  The closest to getting it to go is right after I save the config file on the printer setting page the Mini Fans come on.  Then I try to manually jog the bed and nothing happens.
  • Check that firmware and port/baud rate match your printer and most should work. Remaining parameters are just timing, showing options etc.
