Pi image and AP
Tried the new PI image the other night,  really makes it easy to get started.  I did however hit a snag.  I connected via AP and went the wlan to connect to my network which is secured.  When I clicked on the lan I lost the AP connection before I could ever be prompted for a password.  Seems like it's making the connection and dropping the AP but then failing because it didn't have the password.
I got around this by connecting via Ethernet and then selecting the wlan which I was then prompted for the password and everything worked great from there.
  • Yes, that is in deed a problem we learned after publishing. A should not have tested with dual connection:-) So for next update we need a solution that knows if password is known (ok since we are in AP we might assume it is unknown, otherwise we would be connected).
