Placement of the "script" files
I have two window machines to which I connect the printer depending on place and occasion. I want to be able to synchronise the Repetier settings between them. I do not mind manually copying and renaming files or registry settings.
Where are the configuration data stored? Also where are the little Gcode scriptles (ie what the 1 - 5 uttons do, start&stop code etc) stored ?
Repetier 1.0.6; Windows XP and Windows 7
I am moving bewteen a Win XP and a win 7, but have tried export-delete-import on the win7, too. Same problem.
Should I submit this in the bug-section or will you put it there yourself? A hint for a solution: Store the text as a hex-string (Raw binary, in other words).
