Rasperry Pi Display freezes after selecting the language
Hello guys,
I am running a Rasperry Pi 2+ with the genuine Rasperry Pi display and Repetier Server Pro 0.80.3.
After selecting the language to be French, the display freezed and only says "Intialisation du Logicie!".
Restarting the system didn't help...
What can I do to solve the problem?
Thank you for your help!
  • Looks like french language is not javascript compatible:-) Translation contains lots of ' which is also end of string so it caused javascript errors. Please download
    and copy it to
    /usr/local/Repetier-Server/languages
    and restart server or pi. Then french should also work.
  • It works! Thank you!
    Another question. I disabled the screensaver following this tutorial.
    But it doesn't work. How can I stop the screen from going blank?
  • Check if you have xset installed. It is part of x11utils or similar.
    If you are using our image, set timeout to 0 to disable it in the screensaver display.
  • Thanks! xset is installed, and I disabled everything, the screen stays on but goes darker after some time. Any idea to fix it?
  • That darker is the server screensaver in screensaver window on display. There you can disable hardware and also timing. 0 will disable it, all others are times to darken screen.
