When loading a stl in repetier, and the display pressing the right button to move the object, the program closes. Thus you can not move the pieces on the platform.
Not really. You can select the move object icon on the left to move with left mouse button. I have heard that some linux users have this problem, but not all. Most important not me making it impossible to debug the problem.
We also have always had this problem. Here's the crash output from right clicking. Intel chipset graphics?
Rebuild object False Stacktrace:
at <unknown> <0xffffffff> at (wrapper managed-to-native) object.wrapper_native_0x7fa5e0c5e760 (OpenTK.Graphics.OpenGL.BeginMode,int,OpenTK.Graphics.OpenGL.DrawElementsType,intptr) <0xffffffff> at OpenTK.Graphics.OpenGL.GL.DrawElements (OpenTK.Graphics.OpenGL.BeginMode,int,OpenTK.Graphics.OpenGL.DrawElementsType,intptr) <0x0003c> at OpenTK.Graphics.OpenGL.GL.DrawElements (OpenTK.Graphics.OpenGL.BeginMode,int,OpenTK.Graphics.OpenGL.DrawElementsType,int) <0x00033> at RepetierHostExtender.geom.Submesh.Draw (int,OpenTK.Vector3,bool,bool) <0x005f3> at RepetierHostExtender.geom.TopoGroup.Paint (RepetierHostExtender.interfaces.I3DView) <0x005e3> at RepetierHost.view.ThreeDControl.Picktest (RepetierHostExtender.geom.Geom3DLine,int,int) <0x0118a> at RepetierHost.view.ThreeDControl.gl_MouseDown (object,System.Windows.Forms.MouseEventArgs) <0x0023b> at System.Windows.Forms.Control.OnMouseDown (System.Windows.Forms.MouseEventArgs) <0x00069> at System.Windows.Forms.UserControl.OnMouseDown (System.Windows.Forms.MouseEventArgs) <0x0001b> at System.Windows.Forms.Control.WmRButtonDown (System.Windows.Forms.Message&) <0x000f8> at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message&) <0x00283> at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message&) <0x0001b> at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message&) <0x0005b> at System.Windows.Forms.UserControl.WndProc (System.Windows.Forms.Message&) <0x0006b> at System.Windows.Forms.Control/ControlWindowTarget.OnMessage (System.Windows.Forms.Message&) <0x00025> at System.Windows.Forms.Control/ControlNativeWindow.WndProc (System.Windows.Forms.Message&) <0x00036> at System.Windows.Forms.NativeWindow.WndProc (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x00310> at System.Windows.Forms.XplatUIX11.DispatchMessage (System.Windows.Forms.MSG&) <0x0001f> at System.Windows.Forms.XplatUI.DispatchMessage (System.Windows.Forms.MSG&) <0x0001f> at System.Windows.Forms.Application.RunLoop (bool,System.Windows.Forms.ApplicationContext) <0x00c7f> at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext) <0x0005f> at System.Windows.Forms.Application.Run (System.Windows.Forms.Form) <0x00033> at RepetierHost.Program.Main (string[]) <0x00043> at (wrapper runtime-invoke) <Module>.runtime_invoke_void_object (object,intptr,intptr,intptr) <0xffffffff>
Could not attach to process. If your uid matches the uid of the target process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf ptrace: Operation not permitted. No threads.
================================================================= Got a SIGSEGV while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. =================================================================
Pretty sure that's not a factor. I'm using an external USB mouse, and I didn't have Synaptics installed until last night (to try to work around the RH doesn't run since last Mono update issue.)
Thank You
Stacktrace:
Native stacktrace:
mono() [0x4b73d8]
mono() [0x50f13b]
mono() [0x423d22]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7fa5f9063340]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x150710) [0x7fa5ca94c710]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x150a1e) [0x7fa5ca94ca1e]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x13919f) [0x7fa5ca93519f]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x15090b) [0x7fa5ca94c90b]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x2d7ec8) [0x7fa5caad3ec8]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x134903) [0x7fa5ca930903]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x135c20) [0x7fa5ca931c20]
/usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x136143) [0x7fa5ca932143]
[0x4196b006]
Debug info from gdb:
No threads.
If you are using a notebook or laptop, use a external usb mouse.
