compilation error
Just tried compiling the DEV version today but am getting the following error,
"Arduino: 1.6.12 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch\Eeprom.cpp: In static member function 'static void EEPROM::restoreEEPROMSettingsFromConfiguration()':
Eeprom.cpp:99: error: expected primary-expression before ';' token
     heatedBedController.preheatTemperature = HEATED_BED_PREHEAT_TEMP;
Eeprom.cpp:135: error: expected primary-expression before ';' token
     e->tempControl.preheatTemperature = EXT0_PREHEAT_TEMP;
sketch\Eeprom.cpp: In static member function 'static void EEPROM::readDataFromEEPROM(bool)':
Eeprom.cpp:762: error: expected primary-expression before ';' token
Eeprom.cpp:765: error: expected primary-expression before ';' token
             extruder[0].tempControl.preheatTemperature = EXT0_PREHEAT_TEMP;
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
  • oops, posted in wrong forum, should have been in 'firmware'
    found my error, bed and extruder pre heat options were blank
