Preventing Extruder from Overheating when Temperature Sensor Malfunctions
I'm using Repetier Host to control my Solidoodle 2. Currently, if the thermistor come detached from the extruder, the extruder will continue to heat endlessly because it thinks the temperature is only at room temperature. Is there some code that can be added to prevent this overheating? For example, if the temperature is more than 50 degrees below setpoint and it doesn't get 10% closer within 5 minutes, the printer shuts down.
Thanks,
Tom
