G29 command doesn't seem to want to work
I have a k200 delta and i connected it to repetier everything seemed great. So i start calibrating. I put a M119 code and it said the probe status is L So i pushed the probe and the status turned to W. They since that was correct i put in the G29 command and instantly it said the command failed due to a fatal error and will be fixed. I click ok and then nothing happens. No matter how many time i tried the G29 command didn't work. What should i do?
