Estimated Printing Time has negative value
Morning
I have a question. I am slicing http://www.thingiverse.com/thing:18365/#files (dragonSpikeHigh1) using Slic3r in Repetier host 1.6.2.
After slicing I am seeing an Estimated print time of -8s.
I have see this a few times with some one layer calibration STL files but never with a big model. Is there something I should dbe looking at ?
  • Can you provide a copy of the produced gcode?
    I have seen this when the end contains a G28 resetting time computation. But I thought that has been fixed.
  • Full G-code was to large to fit. I hope you really only need the header and footer information, so here is the beginning and end of the file.
    BEGINNING OF CODE
    generated by Slic3r 1.2.9 on 2017-01-03 at 08:08:07
    ; external perimeters extrusion width = 0.40mm
    ; perimeters extrusion width = 0.67mm
    ; infill extrusion width = 0.67mm
    ; solid infill extrusion width = 0.67mm
    ; top infill extrusion width = 0.67mm
    ; support material extrusion width = 0.40mm
    M107
    M190 S50 ; set bed temperature
    M104 S215 ; set temperature
    G28 ; home all axes
    G1 Z5 F5000 ; lift nozzle
    M109 S215 ; wait for temperature to be reached
    M82 ; use absolute distances for extrusion
    G92 E0
    G1 Z0.180 F7800.000
    G1 E-2.00000 F2400.00000
    G92 E0
    G1 X67.707 Y78.647 F7800.000
    G1 E2.00000 F2400.00000
    G1 X101.484 Y49.568 E4.13924 F1800.000
    END OF CODE
    G1 X101.326 Y121.109 F7800.000
    G1 X100.696 Y120.390 E7.21868 F600.000
    G1 X100.292 Y119.867 E7.25318
    G1 E5.25318 F2400.00000
    G92 E0
    M107
    M104 S0                     ;extruder heater off
    M140 S0                     ;heated bed heater off (if you have it)
    G91                                    ;relative positioning
    G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
    G90                         ;absolute positioning
    G1 Y190                 ;bring bed forward
    M84                         ;steppers off
    ; filament used = 31020.3mm (74.6cm3)
    ; avoid_crossing_perimeters = 0
    ; bed_shape = 0x0,200x0,200x200,0x200
    ; bed_temperature = 0
    ; before_layer_gcode =
    ; bridge_acceleration = 0
    ; bridge_fan_speed = 100
    ; brim_width = 0
    ; complete_objects = 0
    ; cooling = 1
    ; default_acceleration = 0
    ; disable_fan_first_layers = 3
    ; duplicate_distance = 6
    ; end_gcode = M104 S0                     ;extruder heater off\nM140 S0                     ;heated bed heater off (if you have it)\nG91                                    ;relative positioning\nG1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure\nG1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more\nG28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way\nG90                         ;absolute positioning\nG1 Y190                 ;bring bed forward\nM84                         ;steppers off\n
    ; extruder_clearance_height = 20
    ; extruder_clearance_radius = 20
    ; extruder_offset = 0x0
    ; extrusion_axis = E
    ; extrusion_multiplier = 1
    ; fan_always_on = 0
    ; fan_below_layer_time = 60
    ; filament_colour = #FFFFFF
    ; filament_diameter = 1.75
    ; first_layer_acceleration = 0
    ; first_layer_bed_temperature = 50
    ; first_layer_extrusion_width = 0
    ; first_layer_speed = 30
    ; first_layer_temperature = 215
    ; gcode_arcs = 0
    ; gcode_comments = 0
    ; gcode_flavor = reprap
    ; infill_acceleration = 0
    ; infill_first = 0
    ; layer_gcode =
    ; max_fan_speed = 100
    ; max_print_speed = 60
    ; max_volumetric_speed = 0
    ; min_fan_speed = 35
    ; min_print_speed = 10
    ; min_skirt_length = 25
    ; notes =
    ; nozzle_diameter = 0.4
    ; only_retract_when_crossing_perimeters = 1
    ; ooze_prevention = 0
    ; output_filename_format = [input_filename_base].gcode
    ; perimeter_acceleration = 0
    ; post_process =
    ; pressure_advance = 0
    ; resolution = 0
    ; retract_before_travel = 2
    ; retract_layer_change = 0
    ; retract_length = 2
    ; retract_length_toolchange = 10
    ; retract_lift = 0
    ; retract_restart_extra = 0
    ; retract_restart_extra_toolchange = 0
    ; retract_speed = 40
    ; skirt_distance = 3
    ; skirt_height = 1
    ; skirts = 1
    ; slowdown_below_layer_time = 5
    ; spiral_vase = 0
    ; standby_temperature_delta = -5
    ; start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n
    ; temperature = 215
    ; threads = 2
    ; toolchange_gcode =
    ; travel_speed = 130
    ; use_firmware_retraction = 0
    ; use_relative_e_distances = 0
    ; use_volumetric_e = 0
    ; vibration_limit = 0
    ; wipe = 0
    ; z_offset = 0
    ; dont_support_bridges = 1
    ; extrusion_width = 0
    ; first_layer_height = 90%
    ; infill_only_where_needed = 0
    ; interface_shells = 0
    ; layer_height = 0.2
    ; raft_layers = 0
    ; seam_position = random
    ; support_material = 1
    ; support_material_angle = 0
    ; support_material_contact_distance = 0.2
    ; support_material_enforce_layers = 0
    ; support_material_extruder = 1
    ; support_material_extrusion_width = 0
    ; support_material_interface_extruder = 1
    ; support_material_interface_layers = 3
    ; support_material_interface_spacing = 0
    ; support_material_interface_speed = 100%
    ; support_material_pattern = pillars
    ; support_material_spacing = 2.5
    ; support_material_speed = 60
    ; support_material_threshold = 0
    ; xy_size_compensation = 0
    ; bottom_solid_layers = 5
    ; bridge_flow_ratio = 1
    ; bridge_speed = 60
    ; external_fill_pattern = rectilinear
    ; external_perimeter_extrusion_width = 0
    ; external_perimeter_speed = 50%
    ; external_perimeters_first = 0
    ; extra_perimeters = 1
    ; fill_angle = 45
    ; fill_density = 20%
    ; fill_pattern = rectilinear
    ; gap_fill_speed = 20
    ; infill_every_layers = 1
    ; infill_extruder = 1
    ; infill_extrusion_width = 0
    ; infill_overlap = 15%
    ; infill_speed = 50
    ; overhangs = 1
    ; perimeter_extruder = 1
    ; perimeter_extrusion_width = 0
    ; perimeter_speed = 40
    ; perimeters = 3
    ; small_perimeter_speed = 15
    ; solid_infill_below_area = 70
    ; solid_infill_every_layers = 0
    ; solid_infill_extruder = 1
    ; solid_infill_extrusion_width = 0
    ; solid_infill_speed = 20
    ; thin_walls = 1
    ; top_infill_extrusion_width = 0
    ; top_solid_infill_speed = 15
    ; top_solid_layers = 5
  • Could not fully verify but saw
    which is wrong. F param must have a number and no string. I guess it was meant to be replaced but slic3r did not do that and now computation is with F=0 or something different. If it is not that line alone I need the full gcode. Use dropbox/google/pastebin whatever in that case.
  • That was it.  I found it in my end G-code. I used the code in the slicer profile located here http://3dprinterwiki.info/wiki/wanhao-duplicator-i3/duplicator-i3-factory-documentation-files/.  I must not have imported correctly and then I missed it.
    Thanks again for your help.
