How to slow down first layer?
Hi!
I am using repetier-host 1.0.3 on a solidoodle 3 and I am having an issue where the first layer speed seems to be completely ignored when I use curaEngine. I have the first layer set to 12mm/sec but it seems to just be flying around at 40mm/sec, which if course, is a complete disaster. I have to manually slow the print to 30% then speed it up a few layers in, which is very annoying.
Is this a known curaEngine bug or am I doing something wrong? (BTW slic3r is working perfectly, including slowing for the first layer)
Thanks!
Nebarnix
  • Just tested it and it works as it should be. Make sure you are using the print definition you changed and also remember to save changes before reslicing.
  • Thanks for the reply. I changed absolutely nothing and suddenly its working after several days of not working. That is very strange. Apparently something must have been stuck somewhere in the program or engine?
    Nebarnix
