v0.80.0 Pro: stalls / freezes during print (Communication timeout)
Hello @all,
since updating to v80.0 on my rasPi 3 I experience stalls during every print, e.g. the head stops moving / freezes for ~10 seconds (+creates a blob on the print) and then continues.
I _think_ that how often this occurs depends on the actual print-speed (e.g. 100% vs. 70% or lower) set within the Web-GUI; the lower the setting the more often it happens...
I haven't figured out where the "sweet spot" is with my printer since my printer is quite fickle during the first two or three layers (I seem to *have* to run with 60-70% of the speed set in repetier-hosts cura-slicer (currently 25mm/s) or the first layer won't stick no matter what I do :-( ), if such a stall happens within layer1-2/3 the print is usally fscked cos' the blob collides with the nozzle and this pushes everything 'somehwere'
The strange thing is that I this behaviour started with the update to v80, while I do confess that I have my fair share of misprints (1st layer problems...) but I never had stalls before.
Except the v80-Update _nothing_ has changed (neither the raspbian-distro running on the Pi nor Repetier-Host on my Win7-Machine, no Windowsupdates, nothing... I *did* update Repetier-Server on the Win7-Box yesterday 'cos the Pi redused to offload render-jobs to this box but the stalls happened before too)
Stalls look like in the Pi's logfile (if you need a full log please contact me via email):
< 19:05:42.336: N3404 G1 F840 X80.217 Y53.178 E1210.93269
> 19:05:42.365: ok
< 19:05:42.365: N3405 G0 F2700 X80.217 Y53.673
> 19:05:47.427: ok
< 19:05:47.428: M117 Layer 2/50
< 19:05:47.428: N3406 M105
< 19:05:47.429: N3407 M105
> 19:05:47.513: ok
> 19:05:47.518: ok T:210.0 /210.0 B:50.0 /50.0 T0:210.0 /210.0 @:44 B@:0
< 19:05:47.518: N3408 G1 F840 X25.567 Y108.323 E1213.18194
> 19:05:47.522: ok T:210.0 /210.0 B:49.9 /50.0 T0:210.0 /210.0 @:45 B@:0
> 19:05:47.525: ok
< 19:05:47.526: N3409 G0 F2700 X26.062 Y108.323
> 19:05:47.628: ok
< 19:05:47.629: N3410 G1 F840 X80.217 Y54.168 E1215.41081
> 19:05:47.636: ok
< 19:05:47.636: N3411 G0 F2700 X80.217 Y54.663
> 19:05:47.640: ok
< 19:05:47.640: N3412 G1 F840 X26.557 Y108.323 E1217.61931
> 19:05:47.644: ok
< 19:05:47.644: N3413 G0 F2700 X27.052 Y108.323
> 19:05:47.648: ok
< 19:05:47.648: N3414 G1 F840 X80.217 Y55.158 E1219.80744
> 19:05:50.933: ok
< 19:05:50.934: N3415 M105
< 19:05:50.934: N3416 M105
< 19:05:50.935: N3417 G0 F2700 X80.217 Y55.653
> 19:05:55.778: ok
> 19:05:55.783: ok T:209.8 /210.0 B:50.5 /50.0 T0:209.8 /210.0 @:46 B@:0
> 19:05:55.787: ok T:209.8 /210.0 B:50.5 /50.0 T0:209.8 /210.0 @:46 B@:0
< 19:05:55.788: N3418 M105
< 19:05:55.788: N3419 M105
> 19:06:00.547: ok T:209.7 /210.0 B:50.8 /50.0 T0:209.7 /210.0 @:47 B@:0
< 19:06:00.547: M117 ETA 20:57:45 day 23
< 19:06:00.548: N3420 M105
> 19:06:00.554: ok T:209.7 /210.0 B:50.8 /50.0 T0:209.7 /210.0 @:47 B@:0Nok
< 19:06:00.555: N3421 M105
> 19:06:00.558: ok T:209.7 /210.0 B:50.8 /50.0 T0:209.7 /210.0 @:47 B@:0
> 19:06:00.562: ok T:209.7 /210.0 B:50.8 /50.0 T0:209.7 /210.0 @:47 B@:0
< 19:06:00.563: N3422 G1 F840 X27.547 Y108.323 E1221.97520
> 19:06:00.566: ok
> 19:06:31.566: Warning: Communication timeout - resetting communication buffer.
> 19:06:31.566: Connection status: Buffered:46, Manual Commands: 2, Job Commands: 5000
> 19:06:31.566: Buffer used:46 Enforced free byte:35 lines stored:1
< 19:06:31.567: M117 ETE 01:51:44
< 19:06:31.567: N3423 M105
< 19:06:31.567: N3424 M105
> 19:06:31.571: ok
< 19:06:31.572: N3425 G0 F2700 X28.042 Y108.323
> 19:06:31.576: ok T:209.8 /210.0 B:50.5 /50.0 T0:209.8 /210.0 @:45 B@:0
> 19:06:31.576: ok
> 19:06:31.580: ok T:209.8 /210.0 B:50.5 /50.0 T0:209.8 /210.0 @:45 B@:0
I haven't tried the newly available RasPi-Image from your site just yet (no second SD-Card big enough available and I didn't want to nuke the one available since it's driving the printer...) so I can't be sure whether my RaspiCam causes issues (getting this thing to work with v70.x needed quite some faffin' around..)
Any ideas?
THX very much in advance!
> 19:05:42.365: ok
> 19:05:47.427: ok
> 19:05:47.513: ok
> 19:05:47.525: ok
> 19:05:47.628: ok
> 19:05:47.636: ok
> 19:05:47.640: ok
> 19:05:47.644: ok
> 19:05:47.648: ok
> 19:05:50.933: ok
> 19:05:55.778: ok
> 19:06:00.566: ok
> 19:06:31.571: ok
> 19:06:31.576: ok
Any ideas?
Changing the firmware could be tricky since I do not have the sources for the one that's running on this printer right now... so if I mess something up within my new firmware things could get interesting since I have no way to roll back to a known good one :-/
Thank you for now, will keep you in the loop.
since 0.80.2 didn't make it today (and somebody had ants in his pants ;-)) I decided to switch to the current raspi-image.
hoohum..:
- display ETE is set to off (wasn't quite sure where to set this, RepetierHost and/or Server so I unchecked both) but STILL shows up on my display (Reprap Discount something)
- the only thing I changed within the printer-setup was the buffer size, went from 127 to 63.
now... it's still early days (print on nearly the full plate-size -150x150 and the cylinder has ~120mm in diameter-) and I'm on Layer 3 now: no stall/blobs so far and things look VERY promising...
to sum up all changes since yesterday:
- switched from stock raspian (installed RepetierServer myself + quite some faffin' around with recompiling ffmpeg since avconf did not support some parameters submitted by repetier) to your ReadyToRun-Image v80.1
- ran raspi-update (the one thingy where you ssh into your Pi, submit raspi-config and run an update there)
- changed the buffer-size from 127 (default) to 63, I'm not quite sure what was set within the previous configuration; can't check since the printer is running right now and my PC here is running Win7...
- since the 4GB SD-card I used until now was too small to dd the new image onto it I switched to a 16GB Kingston-something
--> could this be the cuplrit? I do know that RasPis are somewhat picky with the SD-card you feed them with and had some trouble with my <other> RasPis running OpenElec...
That's it...
/still too many changed variables at once to nail down the cause, dammit :-/
*knockin' on wood* & blaming systemd 'cos there *has* to be a scapegoat :-D
P.S: exporting and importing my printer-configuration from "old raspian" to the new image failed with "invalid configuration file" and I don't see any severe differences between "working/blobbing printer 'old'" and the new configuration created/exported from scratch.
-> If you're interested I'll upload both of them to our webserver for examination (can't find an upload-button or somesuch here and copypasta of xml-files into some forum-software usually goes wrong in my experience)
to finish this up:
thumbs UP for your exceptional support & response-times, I don't know what I would do without Repetier.
THANKYOU!
to keep you in the loop:
got the sourcecode for my old firmware today (Marlin / grbl mashup) and "ported" the relevant configuration to you firmware-configurator.
Got bitten with (https://forum.repetier.com/discussion/1969/error-compilation-in-eepron-cpp-error-expected-primary-expression-before-token), for me the cause were the weird(?) settings for the heatbed's PID as copied from the original source:
HEATED_BED_PID_IGAIN 0.23
HEATED_BED_PID_DGAIN 305.4
these came in empty from your configurator and caused the compiler to throw a fit.
(I'm currently waiting for the bed to cool down so I can run the M303-autotune-stanza, maybe I get values that 'stick' within the configurator so I don't have to remember where to fiddle around when your next firmware-version comes out ;-))
As far I can see -haven't done a print yet- all controls are working, the display is smoother than with the old firmware too..
The one strange thing I noticed is that it's possible to "overrun" the endstops via Display-wheel.
e.g. on the hisplay
- Home <Axis>
- Position (fast or slow, doesn't matter) -> turn the wheel into "direction of Endstop" -> the axis-coordinate shown on the display happily increases (no movement on the axis itself)
My setup is somewhat weird (seen standing in front of the printer):
X/Y 0 is on back/right
X/Y (max) on front left, X+150 / Y+150
If I home Y and turn the wheel so that Y moves "away from me" Y goes to -1..-5..-10 and so on
BUT: if I the turn the wheel into the other direction (Y moves toward me) the axis moves immediately and not when 0 is reached;
e.g. if I wheel from Y(home) to Y -10 (1mm / click = 10 clicks clockwise, NO axis-movement!) and then 1 click _counterclockwise_ the axis is 1mm away from the endstop and the display shows Y -9... (huh.. same in X and -I assume- in Z)
back to 127 bytes buffer, 2 successful small prints with ~20min runtime: no problems at all
the third one is currently running, all stops pulled (no faffin' around with slower speed at the first layer...)
-> no stalls/blobs
YAY!
... will have to talk _strongly> to <vendor>, the old firmware cost me quite some gray hairs and *hours* of cursing.
Now this is gonna be a *good* weekend, not sure if I'll get out from by man-cave until monday :-D
THANKYOU!
-> I will leave this adventure for another weekend
to sum it up & trying to not derail this thread completely:
- Blobs gone after updating to Reptetier Firmware 0.92.9
-> printer driver (a.k.a. me) is happy ;-)
