0.80.1 Touchscreen interface only sees default G-code directory
in Bug Reports
The new touchscreen interface is mostly working great with Raspberry Pi now, but when selecting G-Code, it only shows the files in the default location. Files in user defined groups are not accessible.
G-code files in these locations must be started remotely via web browser.
I can select another group in the touchscreen interface, but the content is always only what is in the default group.
It appears that group selection is not working at all in the touchscreen interface.
If I select any user defined group, it only shows the default group content.
If I select "all", it only shows the default group content.
From the web browser, it works correctly.
