0.80 not running start and end scripts
I have Repetier-Server pi connected to my davinci with Repetier firmware. Before updating to 0.80 I had no problems printing and all was good but after the update the server starts a job ok temperature of the bed and extruded raise to correct temp but then nothing else happens.
The start script does not seem to run and neither does the end script or cancel script if I stop it.
The connection to the server also seems to drop out if the print is stopped.
If I directly connect the printer to print all is fine and when the server was on 0.75 everything was ok.
I have tried the new pi image too and the same result.
Any help would be appreciated.
Nothing else happens start script etc.
If I try the stop button to cancel the end script is not run either.
It's "Initializing Application" forever.
got nginx working and received a error message!
at CompileMetadataResolver._addTypeToModule (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:14:3008)
at CompileMetadataResolver._addDirectiveToModule (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:14:4054)
at http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:14:853
at Array.forEach (native)
at CompileMetadataResolver.getNgModuleMetadata (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:14:675)
at RuntimeCompiler._compileComponents (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:20:21204)
at RuntimeCompiler._compileModuleAndComponents (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:20:19713)
at RuntimeCompiler.compileModuleAsync (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:20:19319)
at PlatformRef_._bootstrapModuleWithZone (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:15:9947)
at PlatformRef_.bootstrapModule (http://raspberrypi/modules/front2/www/vendor.bundle.js?lang=de&front=1&7b4bb4500096dea88280:15:9575)
Have you tried with PI 3 and another wifi dongle connected in USB?
In that case the dhcp on "wlan0" (on-board wifi in "AP" mode, with ip 10.10.10.1) don't assign any ip number.
