CNC Router on Raspi Repetier Server 0.8
Under the 0.8 version you can manually move the milling machine but no more
"print" NC code.
In previous versions it worked.
Is there a solution to this problem?
CNC Router Mostly Printed CNC
Marlin FW.
Sebastian
  • We only send gcodes unchanged and that part hasn't changed. So please elaborate "print" NC code. What part from it does not work, what does log say.
