[0.80.0] Can't connect to any of my Printer after Upgrade
Hello, I have Repetier Server installed on a Linux-Server running Ubuntu 16. I installed the Server with the Version 0.75 and after upgrading to 0.80, the Server says that all my Printers are offline. I tried un- and re-plugging them but it didn't helped. And under the Printersettings, the Server says that he sees all the Ports, but he still says there are offline.
tail -200 /var/lib/Repetier-Server/logs/server.log
return?
2016-10-26 17:37:09: Printer thread for K8400 stopped
2016-10-26 17:37:09: Printer thread for Kossel stopped
2016-10-26 17:37:09: Printer thread for Freesculpt1 stopped
2016-10-26 17:37:09: Closing user database.
2016-10-26 17:37:09: Server is now down.
2016-10-26 17:37:56: Start logging...
2016-10-26 17:37:56: Webdirectory: /usr/local/Repetier-Server/www/
2016-10-26 17:37:56: Storage directory: /var/lib/Repetier-Server/
2016-10-26 17:37:56: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
2016-10-26 17:37:56: Directory for temporary files: /tmp/
2016-10-26 17:37:56: Reading firmware data ...
2016-10-26 17:37:56: Starting Network ...
2016-10-26 17:37:56: Active features:4095
2016-10-26 17:37:56: Reading printer configurations ...
2016-10-26 17:37:56: Reading printer config /var/lib/Repetier-Server/configs/K8400.xml
2016-10-26 17:37:56: Starting printjob manager thread for K8400
2016-10-26 17:37:56: Reading printer config /var/lib/Repetier-Server/configs/Kossel.xml
2016-10-26 17:37:56: Starting printjob manager thread for Kossel
2016-10-26 17:37:56: Reading printer config /var/lib/Repetier-Server/configs/Freesculpt1.xml
2016-10-26 17:37:56: Starting printjob manager thread for Freesculpt1
2016-10-26 17:37:56: Starting printer threads ...
2016-10-26 17:37:56: Starting printer thread for K8400
2016-10-26 17:37:56: Starting work dispatcher subsystem ...
2016-10-26 17:37:56: Starting user database ...
2016-10-26 17:37:56: Initalizing LUA ...
2016-10-26 17:37:56: Starting printer thread for Freesculpt1
2016-10-26 17:37:56: Starting printer thread for Kossel
2016-10-26 17:37:56: Register LUA cloud services
2016-10-26 17:37:56: add Repetier-Renderer
2016-10-26 17:37:56: LUA initalization finished.
2016-10-26 17:37:56: Starting web server ...
2016-10-26 17:37:56: Work dispatcher thread started.
2016-10-26 17:37:56: Webserver started.
2016-10-26 17:49:27: Shutting down web server.
2016-10-26 17:49:28: Closing server
2016-10-26 17:49:28: Stopping work dispatcher.
2016-10-26 17:49:28: Work dispatcher thread stopped.
2016-10-26 17:49:28: Waiting for all threads to finish ...
2016-10-26 17:49:28: Worker threads finsihed.
2016-10-26 17:49:28: Stopping printer threads.
2016-10-26 17:49:28: Printer thread for K8400 stopped
2016-10-26 17:49:28: Printer thread for Kossel stopped
2016-10-26 17:49:28: Printer thread for Freesculpt1 stopped
2016-10-26 17:49:28: Closing user database.
2016-10-26 17:49:28: Server is now down.
2016-10-26 17:49:28: Start logging...
2016-10-26 17:49:28: Webdirectory: /usr/local/Repetier-Server/www/
2016-10-26 17:49:28: Storage directory: /var/lib/Repetier-Server/
2016-10-26 17:49:28: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
2016-10-26 17:49:28: Directory for temporary files: /tmp/
2016-10-26 17:49:28: Reading firmware data ...
2016-10-26 17:49:28: Starting Network ...
2016-10-26 17:49:28: Active features:4095
2016-10-26 17:49:28: Reading printer configurations ...
2016-10-26 17:49:28: Reading printer config /var/lib/Repetier-Server/configs/K8400.xml
2016-10-26 17:49:28: Starting printjob manager thread for K8400
2016-10-26 17:49:28: Reading printer config /var/lib/Repetier-Server/configs/Kossel.xml
2016-10-26 17:49:28: Starting printjob manager thread for Kossel
2016-10-26 17:49:28: Reading printer config /var/lib/Repetier-Server/configs/Freesculpt1.xml
2016-10-26 17:49:28: Starting printjob manager thread for Freesculpt1
2016-10-26 17:49:28: Starting printer threads ...
2016-10-26 17:49:28: Starting printer thread for K8400
2016-10-26 17:49:28: Starting printer thread for Kossel
2016-10-26 17:49:28: Starting work dispatcher subsystem ...
2016-10-26 17:49:28: Starting printer thread for Freesculpt1
2016-10-26 17:49:28: Starting user database ...
2016-10-26 17:49:28: Initalizing LUA ...
2016-10-26 17:49:28: Register LUA cloud services
2016-10-26 17:49:28: add Repetier-Renderer
2016-10-26 17:49:28: LUA initalization finished.
2016-10-26 17:49:28: Starting web server ...
2016-10-26 17:49:28: Work dispatcher thread started.
2016-10-26 17:49:28: Webserver started.
2016-10-26 17:49:47: Shutting down web server.
2016-10-26 17:49:47: Closing server
2016-10-26 17:49:47: Stopping work dispatcher.
2016-10-26 17:49:47: Work dispatcher thread stopped.
2016-10-26 17:49:47: Waiting for all threads to finish ...
2016-10-26 17:49:47: Worker threads finsihed.
2016-10-26 17:49:47: Stopping printer threads.
2016-10-26 17:49:47: Printer thread for K8400 stopped
2016-10-26 17:49:47: Printer thread for Kossel stopped
2016-10-26 17:49:47: Printer thread for Freesculpt1 stopped
2016-10-26 17:49:47: Closing user database.
2016-10-26 17:49:47: Server is now down.
2016-10-26 17:50:31: Start logging...
2016-10-26 17:50:31: Webdirectory: /usr/local/Repetier-Server/www/
2016-10-26 17:50:31: Storage directory: /var/lib/Repetier-Server/
2016-10-26 17:50:31: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
2016-10-26 17:50:31: Directory for temporary files: /tmp/
2016-10-26 17:50:31: Reading firmware data ...
2016-10-26 17:50:31: Starting Network ...
2016-10-26 17:50:31: Active features:4095
2016-10-26 17:50:31: Reading printer configurations ...
2016-10-26 17:50:31: Reading printer config /var/lib/Repetier-Server/configs/K8400.xml
2016-10-26 17:50:31: Starting printjob manager thread for K8400
2016-10-26 17:50:31: Reading printer config /var/lib/Repetier-Server/configs/Kossel.xml
2016-10-26 17:50:31: Reading printer config /var/lib/Repetier-Server/configs/Freesculpt1.xml
2016-10-26 17:50:31: Starting printjob manager thread for Kossel
2016-10-26 17:50:31: Starting printjob manager thread for Freesculpt1
2016-10-26 17:50:31: Starting printer threads ...
2016-10-26 17:50:31: Starting printer thread for Freesculpt1
2016-10-26 17:50:31: Starting work dispatcher subsystem ...
2016-10-26 17:50:31: Starting user database ...
2016-10-26 17:50:31: Initalizing LUA ...
2016-10-26 17:50:31: Starting printer thread for Kossel
2016-10-26 17:50:31: Starting printer thread for K8400
2016-10-26 17:50:31: Register LUA cloud services
2016-10-26 17:50:31: add Repetier-Renderer
2016-10-26 17:50:31: LUA initalization finished.
2016-10-26 17:50:31: Starting web server ...
2016-10-26 17:50:31: Work dispatcher thread started.
2016-10-26 17:50:31: Webserver started.
2016-10-26 17:56:01: Printer thread for Kossel stopped
2016-10-26 17:56:14: Starting printjob manager thread for Kossel
2016-10-26 17:56:14: Starting printer thread for Kossel
2016-10-26 18:03:24: Closing websocket for missing ping
2016-10-26 18:08:34: Shutting down web server.
2016-10-26 18:08:35: Closing server
2016-10-26 18:08:35: Stopping work dispatcher.
2016-10-26 18:08:35: Work dispatcher thread stopped.
2016-10-26 18:08:35: Waiting for all threads to finish ...
2016-10-26 18:08:35: Worker threads finsihed.
2016-10-26 18:08:35: Stopping printer threads.
2016-10-26 18:08:35: Printer thread for K8400 stopped
2016-10-26 18:08:35: Printer thread for Freesculpt1 stopped
2016-10-26 18:08:35: Printer thread for Kossel stopped
2016-10-26 18:08:35: Closing user database.
2016-10-26 18:08:35: Server is now down.
2016-10-26 18:08:39: Start logging...
2016-10-26 18:08:39: Webdirectory: /usr/local/Repetier-Server/www/
2016-10-26 18:08:39: Storage directory: /var/lib/Repetier-Server/
2016-10-26 18:08:39: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
2016-10-26 18:08:39: Directory for temporary files: /tmp/
2016-10-26 18:08:39: Reading firmware data ...
2016-10-26 18:08:39: Starting Network ...
2016-10-26 18:08:39: Active features:4095
2016-10-26 18:08:39: Reading printer configurations ...
2016-10-26 18:08:39: Reading printer config /var/lib/Repetier-Server/configs/K8400.xml
2016-10-26 18:08:39: Starting printjob manager thread for K8400
2016-10-26 18:08:39: Reading printer config /var/lib/Repetier-Server/configs/Kossel.xml
2016-10-26 18:08:39: Starting printjob manager thread for Kossel
2016-10-26 18:08:39: Reading printer config /var/lib/Repetier-Server/configs/Freesculpt1.xml
2016-10-26 18:08:39: Starting printjob manager thread for Freesculpt1
2016-10-26 18:08:39: Starting printer threads ...
2016-10-26 18:08:39: Starting printer thread for K8400
2016-10-26 18:08:39: Starting printer thread for Kossel
2016-10-26 18:08:39: Starting printer thread for Freesculpt1
2016-10-26 18:08:39: Starting work dispatcher subsystem ...
2016-10-26 18:08:39: Starting user database ...
2016-10-26 18:08:39: Initalizing LUA ...
2016-10-26 18:08:39: Register LUA cloud services
2016-10-26 18:08:39: add Repetier-Renderer
2016-10-26 18:08:39: LUA initalization finished.
2016-10-26 18:08:39: Starting web server ...
2016-10-26 18:08:39: Work dispatcher thread started.
2016-10-26 18:08:39: Webserver started.
2016-10-26 18:31:00: Shutting down web server.
2016-10-26 18:31:01: Closing server
2016-10-26 18:31:01: Stopping work dispatcher.
2016-10-26 18:31:01: Work dispatcher thread stopped.
2016-10-26 18:31:01: Waiting for all threads to finish ...
2016-10-26 18:31:01: Worker threads finsihed.
2016-10-26 18:31:01: Stopping printer threads.
2016-10-26 18:31:01: Printer thread for K8400 stopped
2016-10-26 18:31:01: Printer thread for Kossel stopped
2016-10-26 18:31:01: Printer thread for Freesculpt1 stopped
2016-10-26 18:31:01: Closing user database.
2016-10-26 18:31:01: Server is now down.
2016-10-26 18:31:45: Start logging...
2016-10-26 18:31:45: Webdirectory: /usr/local/Repetier-Server/www/
2016-10-26 18:31:45: Storage directory: /var/lib/Repetier-Server/
2016-10-26 18:31:45: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
2016-10-26 18:31:45: Directory for temporary files: /tmp/
2016-10-26 18:31:45: Reading firmware data ...
2016-10-26 18:31:45: Starting Network ...
2016-10-26 18:31:45: Active features:4095
2016-10-26 18:31:45: Reading printer configurations ...
2016-10-26 18:31:45: Reading printer config /var/lib/Repetier-Server/configs/K8400.xml
2016-10-26 18:31:45: Starting printjob manager thread for K8400
2016-10-26 18:31:45: Reading printer config /var/lib/Repetier-Server/configs/Kossel.xml
2016-10-26 18:31:45: Starting printjob manager thread for Kossel
2016-10-26 18:31:45: Reading printer config /var/lib/Repetier-Server/configs/Freesculpt1.xml
2016-10-26 18:31:45: Starting printjob manager thread for Freesculpt1
2016-10-26 18:31:45: Starting printer threads ...
2016-10-26 18:31:45: Starting printer thread for K8400
2016-10-26 18:31:45: Starting work dispatcher subsystem ...
2016-10-26 18:31:45: Starting printer thread for Freesculpt1
2016-10-26 18:31:45: Starting printer thread for Kossel
2016-10-26 18:31:45: Starting user database ...
2016-10-26 18:31:45: Initalizing LUA ...
2016-10-26 18:31:45: Register LUA cloud services
2016-10-26 18:31:45: add Repetier-Renderer
2016-10-26 18:31:45: LUA initalization finished.
2016-10-26 18:31:45: Starting web server ...
2016-10-26 18:31:45: Webserver started.
2016-10-26 18:31:45: Work dispatcher thread started.
2016-10-26 18:48:09: Closing websocket for missing ping
2016-10-26 18:48:32: Closing websocket for missing ping
