Creating new job caused error Not found
we are running Reptier Server on a Raspberry 3 and everything was working fine until yesterday. Since then the Server wont start print jobs. If I start a Job from Repetier Host, it immediately states status idle. When trying to start a print over the http server directly it says starting in the blue field and then nothing happens. In the server.log I found the following:
2016-10-25 19:35:48: Job created: /var/lib/Repetier-Server/printer/ZoneStar/jobs/00000033_X.u
2016-10-25 19:35:48: finish job /var/lib/Repetier-Server/printer/ZoneStar/jobs/00000033_X.u
2016-10-25 19:35:48: Updating info for /var/lib/Repetier-Server/printer/ZoneStar/jobs/00000033_X.g printer ZoneStar
2016-10-25 19:35:48: Creating new job caused error Not found
2016-10-25 19:35:48: Handling action 'listJobs' caused error Not found
2016-10-25 19:35:49: Handling action 'listJobs' caused error Not found
2016-10-25 19:35:51: Updating g-code stats failed: File not found
What happend? I updated to 0.80 afterwards but it did not solve the problem. No i just cant use the webcam anymore
Greetings
Matthias
Matthias
