0.80 pause between layers
Hi
Delta head is briefly pausing between layers?
Regards
Stephen
  • Server is only sending commands, so no special case on layer switch. Check if there is much extra gcode on layer switch. Depencing on slicer config you might have retraction/undo retraction in layer change code and what will be visible as brief pause.
