[0.80] Lost access to touchscreen interface - "page can only be called over localhost"
After upgrading from 0.75.1 to 0.80 via "check for new version" i lost access to the touchscreen interface. Trying to open via http://192.168.0.99:3344/mod/front/800x480/index.html leads to an error message:
For security reasons this page can only be called over localhost IP!
I have no users set up. (I don't really want to setup any users, as I do not want to enforce a login. If somebody walks up to the printers, i need them to be able to use the interface right away.)
Used to work just fine in 0.75.1, so something changed during the upgrade. Is there any way to make this work again?
For now, I've put an iPad next to the printers and are using normal dashboard. But ideally, i'd like to either get the old interface working again - or better yet: get the new touchscreen interface working.
I understand is have to use a reverse proxy, but my understating from your comments above is that, that may no longer be nessasary. Am I missing something?
