Firmware Update via Server + DUE
Good day Repetier,
I have a server running on an Orange Pi One, which works well, but I have run into a "problem" during firmware update for a DUE board when the DUE is connected via it's native USB port.
If the firmware update fails, due to power loss on the DUE, then the DUE starts up with a blank firmware, and in bootloader mode.
If I then try to use the Server to update the firmware then the server tries to disconnect from the "virtual USB Serial" port of the DUE, but it complains that it can't find the port(which doesn't exist as the board is already in bootloader mode) and then the firmware update fails, without actually trying to update the firmware.
Is there any way to force the update, if the board is already in bootloader mode?
Thank you,
Errol
