Nozzle diameter and layer height error
Help, I'm getting an error whilst slicing trying to use the Slic3r config for my second extruder.
Extruder 1 - nozzle diameter 0.4mm first layer height 0.35mm
Extruder 2 - nozzle diameter 1.2mm first layer height 0.8mm
I'm selecting between the two extruders in Repetier Host "print setting" tab. When I use the profile for extruder one it works fine, but selecting extruder two I get an error message saying "first layer height cannot be greater that nozzle diameter". This also freezes Repetier host and need a forced shutdown to clear.
I've tried slicing directly in Slic3r using both extruder settings without trouble.
Has anyone experienced this problem?
Cheers.
