Repetier-Host Crashes Immediately after Slicing
Hello! Thanks for reading through this.
I have downloaded and installed repetier-host. When you open it for the first time, there's an .amf file of a tablet pc stand already. This file has no problem slicing and printing.
However, when I try to slice any .stl file I have loaded, the bar moves across the screen and then the entire application disappears. I get no error message and no dialog box. Mind you, I'm not even sure it's the file type that's the problem. There may be some other thing about the preloaded file that makes it work every time while things I load cause a crash.
Has anyone else had this problem?
Thank you!
Some things that might also be helpful:
1) I'm running Arch Linux.
2) I've tried reinstalling several times, but the problem persists.
3) I've tried installing the CuraEngine separately - and also the git version, but the build seems to unspool and result in never ending text, rather than the organized and annotated build process that results from simply installing repetier-host.
4) Attempts to install Slic3r separately as an alternative to Cura have resulted in similar never ending text gobbledygook.
5) I tried installing straight from the tarball, but the original crash problem persists there, too.
Thank you!
Also, sometimes when I install repetier-host, the tablet .amf is not there when I open it. After I load an .stl, I can slice it without the program quitting - but only the first time. After that, files repetier will not read the file curaengine created, and the same problem picks up again.
I think Mono 4.6.1.3-1 is the one I'm on. It sounds like it wasn't the problem, though. It may have been another library, somewhere. I think I've done more updates just this week than in any month since I first installed the OS.
Either way, I really appreciate your help with it - thank you!
