Decimal values in PWM for M106 Sxx.xxxx
Does Repetier server support having decimal values when using M106 S to control pwm signal?
I am trying to do a raster engrave and the software I have used to generate the gcode does not use whole numbers for M106 S it will use 4 or 5 decimal places.
When I try to launch start the file the interface locks up and I get endless
Error: Line Number is not Last Line Number+1, Last LineL xxx
A vector engrave file works fine with M106 S255 and M107
