Ubuntu 16.04 Install
I'm new to both Ubuntu and Repetier Server, and I'm trying to install Repetier Server 0.75 and I've followed the rather short linux install instructions. When I use "/etc/init.d/RepetierServer start" I get the following:
[....] Starting RepetierServer (via systemctl): RepetierServer.serviceJob for RepetierServer.service failed because the control process exited with error code. See "systemctl status RepetierServer.service" and "journalctl -xe" for details.
failed!
And then systemctl status RepetierServer.service gives:
● RepetierServer.service - LSB: Init script for Repetier-Server
Loaded: loaded (/etc/init.d/RepetierServer; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2016-09-04 22:01:42 EDT; 2min 58s ago
Docs: man:systemd-sysv-generator(8)
Process: 11178 ExecStart=/etc/init.d/RepetierServer start (code=exited, status=2)
Sep 04 22:01:42 EasyBakeServer systemd[1]: Starting LSB: Init script for Repetier-Server...
Sep 04 22:01:42 EasyBakeServer RepetierServer[11178]: * Starting Repetier-Server rsd
Sep 04 22:01:42 EasyBakeServer RepetierServer[11178]: start-stop-daemon: unable to start /usr/local/Repetier-Server/bin/RepetierServer (No such file or directory)
Sep 04 22:01:42 EasyBakeServer RepetierServer[11178]: ...fail!
Sep 04 22:01:42 EasyBakeServer systemd[1]: RepetierServer.service: Control process exited, code=exited status=2
Sep 04 22:01:42 EasyBakeServer systemd[1]: Failed to start LSB: Init script for Repetier-Server.
Sep 04 22:01:42 EasyBakeServer systemd[1]: RepetierServer.service: Unit entered failed state.
Sep 04 22:01:42 EasyBakeServer systemd[1]: RepetierServer.service: Failed with result 'exit-code'.
And journalctl -xe gives:
Unit RepetierServer.service has begun starting up.
-- Subject: Unit RepetierServer.service has failed
-- Defined-By: systemd
-- Unit RepetierServer.service has failed.
-- The result is failed.
Sep 04 22:01:42 EasyBakeServer polkitd(authority=local)[2783]: Unregistered Authentication Agent for unix-process:11168:3925675 (system bus name :1.144, object path /org
lines 1829-1878/1878 (END)
Any help would be greatly appreciated, I'll try to respond if more info is needed.
