when i try to connect a fresh loading of repetiere to a troubled revolutionxl it says it connects successfully then crashes and reports possible api key problem,whats happening? Thanks Jim
The host has no API key. It just uses a api key to connect to the server. So are you using host->server->printer and can you make a screenshot of the problem. This is nothing I have seen so far.
