ffmpeg version problem with raspberry pi2
I'm using RPi2 for my Repetier-Server. All working fine but I'm not able to use timelape.
I know ffmpeg versione on Rpi is old so I downloaded ffmpeg from website.
I try to compile it but I receive an error on option "concat" which is unavailable.
I only enable option --enable-gpl --enable-libx264. There is any other option I need to activate?
Can you provide the full configure options I need to apply to build the right ffmpeg version.
I downloaded last one on ffmpeg website which newer than 1.1 required.
Thanks in advance
Rosario
Thanks in advance
Rosario
unknown input format: 'concat'
I'm adding new info.
I tryed ffmpeg command in a separate shell with debug loglevel.
It seems a ffmpeg error:
/usr/local/bin/ffmpeg -loglevel debug -f concat -i /var/lib/Repetier-Server/printer/MicroRos/timelapse/20160801T195346_SmartRos_CuboAngolox4/input.txt -c:v libx264 -threads 1 -r 30 -pix_fmt yuv420p -profile:v baseline -level 3.0 -movflags +faststart -b:v 1000k -y /var/lib/Repetier-Server/printer/MicroRos/timelapse/20160801T195346_SmartRos_CuboAngolox4/video.mp4 > /tmp/ReptierServer-Timelapse-CreateVideo.log 2>&1
Bus Error
I have a log file ReptierServer-Timelapse-CreateVideo.log which contains all ffmpeg logging info.
How can I attach it on forum?
Can you help to solve issue?
As mentioned before I'm using latest ffmpeg version (3.x) downloaded from relative website (not the raspbian one which 0.8).
ffmpeg version N-80981-gacca56d Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 4.6 (Debian 4.6.3-14+rpi1)
configuration: --enable-gpl --enable-libx264
libavutil 55. 28.100 / 55. 28.100
libavcodec 57. 50.100 / 57. 50.100
libavformat 57. 41.100 / 57. 41.100
libavdevice 57. 0.102 / 57. 0.102
libavfilter 6. 47.100 / 6. 47.100
libswscale 4. 1.100 / 4. 1.100
libswresample 2. 1.100 / 2. 1.100
libpostproc 54. 0.100 / 54. 0.100
As aspected, for raspbian ffmpeg version (old one which is 0.8) I raceived the "unknown input format: concat" error.
With latest ffmpeg versione compiled directly on rpi2 it seems go to the end but all video are of 48byte. When I try to see them videoplayer goes in error for format non supported.
Looking on logs I see Bus Error previously metioned.
I'm trying to compile ffmpeg with various option to find if I'm in trouble with it.
Now a question. How do you installed latest ffmpeg on rpi2? installeing a package or compiling it?
If compiling, can you show all options I need to put in configure command.
Thanks in advance
Rosario
