Ovewrite existing file
Is there an option that can be set that when a file with the same name is uploaded it will ovewrite it?
I often do tests with settings and end uploading the same filename multiple times, currently it creates a new copy listed with the same name what makes it confusing to distinguish in the list.
Thanks!
  • Uploading through host would erase it first. But the normal frontend does not enforce this. In detail view you see date to sort.
