Upgrade from .70 to .75
I was wondering how hard it would be to upgrade from .70 to .75. I have quite a few G-Codes, a webcam setup, and some custom command settings saved. Would all of that be lost if I tried to install the new version? Would I need to delete my current version or can I install .75 directly over .70?
  • Just do the automatic install from web interface. All your settings are in separate directory and will not be deleted. You can simply continue to work, only install with restart server so don't do it while printing.
    Alternative download latest version and run it, which is the same. Autoinstaller just downloads and starts latest version installer.
  • Worked perfectly, thanks!
