PI 3 install error
I would install repeater server in a PI3 with noobs,
i have always the same errors after 2 news reinstall his always the same errors (under the message the terminal text i cut a part the body is too long )  :
if someone have an idea ???
Franck.
pi@raspberrypi:~/Downloads $ sudo dpkg -i Repetier-Server-0.75.1-Linux.deb
(Reading database ... 118080 files and directories currently installed.)
Preparing to unpack Repetier-Server-0.75.1-Linux.deb ...
Unpacking repetier-server (0.75.1) over (0.75.1) ...
dpkg: error processing archive Repetier-Server-0.75.1-Linux.deb (--install):
 unable to create `/usr/local/Repetier-Server/www/manual/images/osx_2.png.dpkg-new' (while processing `./usr/local/Repetier-Server/www/manual/images/osx_2.png'): Read-only file system
dpkg: error while cleaning up:
 unable to remove newly-extracted version of `/usr/local/Repetier-Server/www/manual/images/osx_2.png': Read-only file system
 unable to remove newly-extracted version of `/usr/local/Repetier-Server/www/manual/images/folders.png': Read-only file system
 unable to remove newly-extracted version of `/usr/local/Repetier-Server/etc/RepetierServer.xml': Read-only file system
 unable to remove newly-extracted version of `/etc/init.d/RepetierServer': Read-only file system
 unable to securely remove '/var/lib/dpkg/tmp.ci': Read-only file system
 unable to securely remove '/var/lib/dpkg/reassemble.deb': Read-only file system
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for systemd (215-17+deb8u4) ...
dpkg: unrecoverable fatal error, aborting:
 unable to flush updated status of `systemd': Read-only file system
  • I have no experience with noob, always use Jessy Raspian as start. Your problem is Read-only file system meaning you can not write to your disk. I guess you need to do something to make it a working linux so your filesystem becomes writeable. Or just install jessy image instead and use sudo rpiconfig to expand filesystem.
  • Thanks for your help,
    I have download and install jessy, but new problems , i have nothing after unpacking ?  ( test with armel and armhf)
    pi@raspberrypi:~ $ sudo dpkg -i Repetier-Server-0.75.1-Linux.deb
    Selecting previously unselected package repetier-server.
    Unpacking repetier-server (0.75.1) ...
  • did you redownload the package?
    After install you should have all files in /usr/local/Repetier-Server but it looks like your output s incomplete or the rest of the installation process does not occur.
    Have you expanded the filesystem? df shows file system usage. On install you only have the same size as original image and not your sd card size. That is what sudo rpiconfig offsers (expand filesystem).
  • yes i have a new test : download jessie in raspberry.org/ install the image with W32diskimage
    i have do : sudo raspi-config and expand filesystem  and reboot  ////// it s ok ?????
    after i download by the web browser of the pi the armhf file
    by ssh command i do sudo dpkg -i Repetier-Server-0.75.1-Linux.deb
    and after unpack error read only file system !!!
    in usr/local/Repetier-Server  i have : bin   etc  languages and modules ( and files in the repertoires)
     unable to remove newly-installed version of `/usr/local/Repetier-Server/etc': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/bin/rootcert.pem': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/bin/RepetierInstaller': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/bin/RepetierServer': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/bin/RepetierRenderer': Read-only file system
     unable to remove newly-installed version of `/usr/local/Repetier-Server/bin': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/zh.po': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/pt.mo': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/it.mo': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/zh.mo': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/de.po': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/de.mo': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/it.po': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/.AppleDouble/.Parent': Read-only file system
     unable to remove newly-installed version of `/usr/local/Repetier-Server/languages/.AppleDouble': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/pt.po': Read-only file system
     unable to remove newly-extracted version of `/usr/local/Repetier-Server/languages/aliases.ini': Read-only file system
     unable to remove newly-installed version of `/usr/local/Repetier-Server/languages': Read-only file system
     unable to remove newly-installed version of `/usr/local/Repetier-Server': Read-only file system
  • i return in the expand filesystem , it s not a problem of space free in the disk in file manager i have free space 24 GiB ( total: 28.5 GiB)
  • pi@raspberrypi:~ $ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root        29G  3.4G   24G  13% /
    devtmpfs        459M     0  459M   0% /dev
    tmpfs           463M     0  463M   0% /dev/shm
    tmpfs           463M  6.4M  457M   2% /run
    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
    tmpfs           463M     0  463M   0% /sys/fs/cgroup
    /dev/mmcblk0p1   63M   21M   43M  33% /boot
    tmpfs            93M     0   93M   0% /run/user/1000
    pi@raspberrypi:~ $
  • Good news !!!
    it s ok install ok, the Kingston 32 gb HC10  is not compatible / test with 2 card new !!!
    some exemple of the same problem in the net with 16 and 32 Gb of kingston  .....
    test with a 16 gb scandisk and all is good at the first install
    thanks for help ( i can make resolve in the post ???)
    Franck.
