[0.75.1] Extra movement past 0 allowed
I have tried this with two separate printers. When I use the Control interface and use the arrow buttons under the "Move" sidebar on the right, the interface allows me to move the axis one more time after it's reached is limit. Say I move the Z axis down to 0, then press the down button one more time. The result is that the print head crashes into the print bed (this is for printers where the end stop is at the top, such as the LulzBot Mini).
  • You are right. I have checked it and it has no check.
    Next release will add a check if you homed. For unhomed printers it will still allow this as we do not know where we really are.
  • Awesome, thank you.
  • perfect, I just logged in to report the same bug... :-)
