error compiling
Hi
Help
I'm having trouble uploading firmware on the Arduino Mega 2560
I RAMPS v1.4 motherboard
I have Windows 7
I use version 1.6.5
Errors:
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp: In member function 'void UIDisplay::adjustMenuPos()':
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2016:47: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
     uint8_t mtype = HAL::readFlashByte((const prog_char*)&(men->menuType));
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2016:41: error: expected primary-expression before 'const'
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2016:41: error: expected ')' before 'const'
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp: In member function 'void UIDisplay::nextPreviousAction(int8_t)':
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2083:47: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2083:41: error: expected primary-expression before 'const'
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2083:41: error: expected ')' before 'const'
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2087:49: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
     uint8_t entType = HAL::readFlashByte((const prog_char*)&(ent->menuType));// 0 = Info, 1 = Headline, 2 = submenu ref, 3 = direct action command
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2087:43: error: expected primary-expression before 'const'
C:\Users\HAMEDH~1\AppData\Local\Temp\build3078220038397651215.tmp\ui.cpp:2087:43: error: expected ')' before 'const'
Error compiling.
Please, help.
  • You forgot the most important information - firmware version. 0.91 needs 1.0.6 or older to compile. 0.92 works with latest arduino versions.
