Scaling isn't honored
When I design objects in Sketchup, I draw everything at x1000 and display units in meters. This gets around the issues of resolution limits in Sketchup.
Export to an STL is done with export units set to mm. Cura correctly interprets the object's size.
When I tried to use Repetier Host with import units set to mm, the object imported as though it was in meters rather than in mm. When I set the import units to meters, the object cannot be found on the screen.
Scaling the object within Repetier results in the object being the correct size, but then the offset information shows tens of thousands of mm. Repetier host also locks auto-placement as soon as I try to load a second object on the platform because it considers the platform to be over-filled.
So, am I doing something wrong or does Repetier Host not honor the units specified by the imported STL?
https://www.dropbox.com/s/uh8j4r71hxpn65r/corexy pulley slide 3_fixed.stl?dl=0
The actual object is 48.78mm x 47.03mm x 35.43mm. As I indicated, this object does load and print properly with Cura 15.04.
Here is an image of the object.
Strangely, Repetier Host also re-scaled or interpreted it as mm!
This was true only when import units was set to mm.
Here is a link to the Model Units file
https://www.dropbox.com/s/h33d3uy03cjzxsz/corexy pulley slide 3_model units.stl?dl=0
